Editing WavPack
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 98: Line 98:
=== Other tools ===
=== Other tools ===
* [http://mr-questionman.en.uptodown.com/windows Mr. QuestionMan]
* [http://www.burrrn.net/?page_id=5 Mr. QuestionMan]
* [http://www.bunkus.org/videotools/mkvtoolnix/ mkvtoolnix] – tool to multiplex WavPack streams inside the Matroska container
''It's worth mentioning the [[Matroska]] guys decided to concentrate on WavPack as the lossless compressor of choice for their container. Quite an honor... :-)''
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Template used on this page:
