Editing Lossless comparison
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 84: Line 84:
| Hardware support
| Hardware support
| style="background: #00FF00" | very good
| style="background: #CCFFCC" | good
| style="background: #FFCC66" | limited
| style="background: #FF9900" | no
Line 94: Line 94:
| Software support
| Software support
| style="background: #FFCC66" | average
Line 137: Line 137:
| style="background: #00FF00" | yes
| style="background: #FFCC66" | no{{ref label|tak_os|F|F}}
Line 183: Line 183:
https://alac.macosforge.org/trac
[[ALAC]] is a codec developed by Apple and used across their hardware and software platforms.
[[ALAC]] is a codec developed by Apple for usage in [[Apple iPod|iPod]] and AirPort Express.
'''ALAC pros'''
'''ALAC pros'''
Line 202: Line 202:
* No error detection/robustness<ref>[http://www.hydrogenaud.io/forums/index.php?s=&showtopic=33226&view=findpost&p=862031 HA forum post discussing ALAC robustness]</ref>
* No hybrid/lossy mode (and not [[LossyWAV]] compatible)
* Not very efficient
''' ALAC Other features '''
Line 217: Line 218:
* Very good hardware support (Android, Marantz, Sonos, [http://xiph.org/flac/links.html many others])
* Very good software support
* Independent encoder implementations available: flake/ffmpeg, FLACCL (which is insanely fast, and can beat any other CPU based encoder)
* Error robustness
* Error robustness
* Streaming support
* Streaming support
Line 234: Line 235:
* Supports embedded CUE sheets (with [http://flac.sourceforge.net/faq.html#general__no_cuesheet_tags limitations])
* Includes MD5 hashes for quick integrity checking as standard
* Fits the [[Ogg]], [[Matroska]] and [[MP4]] (experimental) containers
* Fits the [[Ogg]] and [[Matroska]] containers
=== Monkey's Audio (APE) ===
Line 255: Line 256:
''' APE cons '''
''' APE cons '''
* Problematic license (Source available, but with no modification or redistribution rights. Encourages violating the GNU GPL license of other programs.)
* Problematic license (source provided, no modification or redistribution rights)
* Slow decoding
* Slow decoding
Line 366: Line 367:
* Pipe support
* Pipe support
* Good software support
* Works with Android (Through third party software, such as VLC.)
* Independent encoder implementation available. (FFmpeg WavPack)
''' WV cons '''
''' WV cons '''
* Limited hardware player support ([http://www.rockbox.org/ RockBox])
* More than one tagging method allowed (Ambiguity possible, but unlikely as APEv2 tags have been the preferred method for quite some time.)
* More than one tagging method allowed (ambiguity possible)
''' WV Other features '''
Line 389: Line 388:
''' WMAL pros '''
''' WMAL pros '''
* Streaming support
* Streaming support
* Hardware support (Microsoft Zune, [http://en.wikipedia.org/wiki/Gigabeat Gigabeat V and S line from Toshiba])
* Supports [[multichannel]] audio and [[high resolution]]s.
* Tagging support (proprietary)
Line 394: Line 395:
''' WMAL cons '''
''' WMAL cons '''
* Limited hardware support (Microsoft Zune, Toshiba Gigabeat S and V. Both discontinued and obsolete. Rockbox, for 16-bit stereo files only.)
* Rather low efficiency
* Limited software support outside of the Microsoft Windows operating system.
* Extremely low efficiency
* Closed source
* Closed source
* No hybrid/lossy mode (but is [[LossyWAV]] compatible)
Line 416: Line 415:
====MLP/Dolby TrueHD====
The [[MLP|MLP codec]] (of which the mathematical basis was used in Dolby TrueHD) is the codec used for DVD-Audio. It was mandatory in any HD-DVD implementation and optional for Blu-Ray in its Dolby TrueHD form. It is known to support the 'wasted bits' scheme used in LossyWAV. As encoders are very expensive, its use outside DVD/Blu-ray mastering environments is non-existent. Its main use is encoding surround sound data.
The [[MLP|MLP codec]] (of which the mathematical basis was used in Dolby TrueHD) is the codec used for DVD-Audio. It was mandatory in any HD-DVD implementation and optional for Blu-Ray in it's Dolby TrueHD form. It is known to support the 'wasted bits' scheme used in LossyWAV. As encoders are very expensive, its use outside DVD/Blu-ray mastering environments is non-existent. Its main use is encoding surround sound data.
====MPEG-4 ALS====
====MPEG-4 ALS====
Line 433: Line 432:
====Oddball formats====
There are a few archaic formats of which encoders and decoders are hard to come by. Most of those would have disappeared by now, but some of them are being preserved for posterity at [[User:Rjamorim|rjamorim]]'s
There are a few archaic formats of which encoders and decoders are hard to get by. Most of those would have disappeared by now, but some of them are being preserved for posterity at [[User:Rjamorim|rjamorim]]'s
* Advanced Digital Audio (ADA)
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Templates used on this page:
