Editing Lossless comparison
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 416: Line 416:
====MLP/Dolby TrueHD====
The [[MLP|MLP codec]] (of which the mathematical basis was used in Dolby TrueHD) is the codec used for DVD-Audio. It was mandatory in any HD-DVD implementation and optional for Blu-Ray in its Dolby TrueHD form. It is known to support the 'wasted bits' scheme used in LossyWAV. As encoders are very expensive, its use outside DVD/Blu-ray mastering environments is non-existent. Its main use is encoding surround sound data.
The [[MLP|MLP codec]] (of which the mathematical basis was used in Dolby TrueHD) is the codec used for DVD-Audio. It was mandatory in any HD-DVD implementation and optional for Blu-Ray in it's Dolby TrueHD form. It is known to support the 'wasted bits' scheme used in LossyWAV. As encoders are very expensive, its use outside DVD/Blu-ray mastering environments is non-existent. Its main use is encoding surround sound data.
====MPEG-4 ALS====
====MPEG-4 ALS====
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Templates used on this page:
