Editing Lossless comparison
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 2: Line 2:
== Introduction ==
== Introduction ==
Given the enormous number of [[lossless]] audio compressor choices available, it is a very difficult task to choose the one most suited for each person's needs. Some people take into consideration only compression performance when choosing a codec, but as the following table and article shows, there are several other features worth taking into consideration when making a choice.
Given the enormous number of [[lossless]] audio compressor choices available, it is a very difficult task to choose the one most suited for each person's needs. Some people only take into consideration compression performance when choosing a codec, but as the following table and article shows, there are several other features worth taking into consideration when making a choice.
For example, users wanting good multiplatform compatibility and robustness (e.g., people sharing live recordings) would favour [[WavPack]] or [[FLAC]]. Another user, looking for the very highest compression available, would go with [[OptimFROG]]. Someone wanting portable support would use [[FLAC]] or [[ALAC]], and so on. En fin, this is not a matter worth getting too worked up about. If you later find out the codec you chose isn't the best for your needs, you can just transcompress to another format, without risk of losing quality.
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Templates used on this page:
