Editing Lossless Audio
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 4: Line 4:
* Compresses files better than almost any other current lossless encoder
* Available for Windows (win32) and Linux/x86 (binaries only).
* [[XMMS]] + [[Winamp]] plugin available
* xmms + WinAMP plugin available
== Cons ==
== Cons ==
* Very slow encode and decode (realtime on 700–800 MHz CPU)
* Very slow encode and decode (realtime on 700-800mhz CPU)
* No source code or format specification available.
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
