Editing Introduction to Vinyl
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 1: Line 1:
''This page has been split up into [[Advantages of Vinyl]], [[Disadvantages of Vinyl]] and [[Vinyl Myths]].''
=Why vinyl?=
Why invest in an obsolete, 50+ year old music medium?
* Used vinyl is often extremely inexpensive - 50 cents to two dollars a disc is somewhat common. Vinyl is a very cheap way to expand your collection in older artists that you cannot justify spending $15/CD on listening to.
* Some albums have simply never been released on CD.
* Some album art is better suited to the larger scale of LP covers and sleeves.
* The mastering of an original LP release is often considered superior to a CD remaster of the same release. This can be for any number of reasons, including:
** Increased use of compression and limiting on the CD release, reducing dynamics
** The master tapes have often degraded in the time between the LP and CD releases
** The equalization and even mixing of some CD releases is radically different than on the LP releases. For instance, many Zappa LPs have had entire drum tracks replaced for the CD release.
* Properly maintained vinyl is of a surprisingly good quality and is often not objectionable.
=Why not vinyl?=
There are several disadvantages.
* Vinyl is particularly finicky to [[Vinyl Maintenance|maintain]] and easy to damage.
* [[Surface noise]], while often inaudible, will always be present, even on a brand new LP.
* The quality of a record often cannot be determined until you play it, increasing the risk of the purchase. Even brand new, sealed LPs can have significant pressing and warping problems.
* Not portable.
* Investing in a reasonable vinyl system is hundreds to thousands of dollars more expensive than investing in a reasonable CD/computer system. Financially, any benefits of the cheaper media must be compared against the amortized cost of the equipment needed to play and maintain it.
* There is also a not insignificant running cost in playing LPs. The [[stylus]] does wear out, and top class [[Cartridge|cartridges]] use stylii costing several hundred (or even thousand) dollars. Playing one LP with an audiophile [[cartridge]] can easily cost over a dollar in stylus wear.
* Records are large and heavy. Transporting them correctly is logistically difficult.
* Many record stores have a considerable markup on used LPs and it may be hard to find records for cheaper than $10 in some stores. This makes it much harder to completely justify vinyl on a financial basis.
* Some vinyl has a very high collector's value which makes it nearly impossible to locate for prices cheaper than CD.
=Vinyl Myths and Misconceptions=
''Note: These are preliminary notes, are a little opinionated, and are subject to change. Please edit as appropriate or comment on the discussion page.''
* '''The vinyl surface is heated to several hundred degrees on playback, and repeat play of the same track should wait until the vinyl has cooled'''.
* '''Proper vinyl playback is click-free.'''
* '''Vinyl is better than digital because the analog signal on the vinyl tracks the analog signal exactly, while digital is quantized into steps.'''
* '''Vinyl is objectively worse than digital.'''
* '''Vinyl is objectively better than digital.'''
* '''Adding a penny to the headshell improves tracking/sound.'''
* '''Vinyl sounds better with the dustcover on/off.'''
* '''A cartridge is permanently damaged and should be replaced if the stylus appears even slightly bent.'''
* '''A record cleaning machine is required for proper playback.'''
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
