View source for Foobar2000:Properties/Partial Info
Jump to: navigation, search
You do not have permission to edit this page, for the following reason:
Your username or IP address has been blocked.
The block was made by DNSBL. The reason given is Your IP address is listed as an open proxy in the DNSBL used by Hydrogenaudio Knowledgebase..
  • Start of block: 14:13, 20 September 2021
  • Expiry of block: 14:13, 20 September 2021
  • Intended blockee: 3.238.132.225
You can contact DNSBL or another administrator to discuss the block. You cannot use the "email this user" feature unless a valid email address is specified in your account preferences and you have not been blocked from using it. Your current IP address is 3.238.132.225, and the block ID is #. Please include all above details in any queries you make.
You can view and copy the source of this page:
Template used on this page:
Return to Foobar2000:Properties/Partial Info.
