Editing Foobar2000:Properties
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 95: Line 95:
The difference between "Paste" and "Paste Fields" commands is that "Paste" replaces currently selected fields' values with field values currently present in Windows Clipboard - regardless of names of fields that you copied before; "Paste Fields" behavior doesn't depend on current selection - it creates new fields with names and values present in Windows Clipboard - if fields with matching names already exist, they're overwritten. For an example: if you copy the "title" field, you can use the "Paste" command to put titles in the "comment" field, but the "Paste Fields" will always overwrite contents of the "title" field with copied values. "Paste Fields" is mainly intended for transferring full sets of metadata between different tracks.
To completely transfer metadata between two groups of tracks, open the Properties dialog for the source group, select all metadata fields, right-click, choose "Copy"; then open the Properties dialog for the target group, select all metadata fields, choose "Remove" and then "Paste Fields" from the right-click menu. [[Foobar2000:How to transfer tags between two sets of tracks|Read more...]]
==Usage tips==
==Usage tips==
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
