Editing Foobar2000:FAQ
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 90: Line 90:
== I updated my tags, but foobar still shows the old tags.  How can I fix this? ==
This happens almost exclusively when you use a third party program to update tags (updates made by Foobar2000 itself are immediately reflected). Select the file(s), right click on any of them, go to Tagging, then click on "Reload Info from File(s)".
This happens almost exclusively when you use a third party program to update tags (updates made by Foobar2000 itself, are immediately reflected). Select the file(s), right click on any of them, go to Tagging, then click on "Reload Info from File(s)".
== How can I fill in tags based on file names or directory structure? ==
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
