Editing Foobar2000:Components 0.9/Command-Line Decoder Wrapper (foo input exe)
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 2: Line 2:
=Description=
=Description=
The Command-Line Decoder Wrapper allows you to play almost any otherwise unsupported audio format through foobar2000. All you need is a standalone command-line decoder executable that converts your files to one of the supported formats, such as WAV. Such decoders are available for nearly every audio format in existence.
The Command-Line Decoder Wrapper lets allows you to play almost any otherwise unsupported audio format through foobar2000. All you need is a standalone command-line decoder executable that converts your files to one of the supported formats, such as WAV. Such decoders are available for nearly every audio format in existence.
In certain cases, the Command-Line Decoder Wrapper is a superior alternative to the available native foobar2000 decoders if the native decoders are plagued by bugs; this component is inherently multi-instance safe and makes foobar2000 immune to crashes caused by buggy decoders.
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Templates used on this page:
