Editing Foobar2000:Components/Impulse Response Convolver (foo convolve)
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 1: Line 1:
{{stub}}
[[Image:Dsp convolve.PNG|thumb]]
{{Foobar Component Infobox
| name                = Convolver
== Description ==
| screenshot          = [[File:foo_convolve.png|250px]]
| caption              =
| module_name          = foo_convolve
| developer            = Gian-Carlo Pascutto; Peter Pawłowski
| repository          =
| released            =
| released_ref        =
| stable_release      =
| stable_release_date  =
| preview_release      = 0.3
| preview_release_date = {{start date and age|2006|08|04}}
| foobar2000_minimum  = 1.0
| foobar2000_ui_module =
| use                  = DSP
| license              =
* Takes impulse response and does a fast convolution of the sound data with that impulse response.
* Allows quick computation of any combination of linear effects, such as equalization, echo, flange, reverb, phase shift and so on.
Line 23: Line 7:
* See readme.txt for more details.
==External links==
== Link ==
* {{foobar2000|http://www.foobar2000.org/components/view/foo_convolve|Impulse Response Convolver}}
* [http://www.foobar2000.org/components/view/foo_convolve Official Website]
* {{ha|https://hydrogenaud.io/index.php/topic,10611.0.html}}
* [http://www.hydrogenaudio.org/forums/index.php?showtopic=10611 Discussion thread]
* [http://www.sjeng.org/foobar2000.html Garf's Convolver Impulse Response files]
[[Category:foobar2000 DSP Components|Convolve]]
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
