Editing Foobar2000:Components
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 281: Line 281:
* [[Foobar2000:Components 0.9/HTTP Writer (foo_write_http)|HTTP Writer (foo_write_http)]] It's TCP/IP server that listens on a specified port for incoming requests such as play, stop, etc.
* [[Foobar2000:Components 0.9/Joystick Control (foo_joystick_control)|Joystick Control (foo_joystick_control)]] Control foobar2000 from a joystick/gamepad.
* [[Foobar2000:Components 0.9/MIDI Transport(foo_miditransport)|MIDI Transport (foo_miditransport)]] Control Foobar2k from external MIDI controllers (CC and MMC transport).
* [[Foobar2000:Components 0.9/Minibar2k (foo_Minibar2k)|Minibar2k (foo_Minibar2k)]] Control Foobar2k from your PDA (PocketPC based).
* [[Foobar2000:Components 0.9/Remote Control (foo_remotecontrol)|Remote Control (foo_remotecontrol)]] Adds support to Melloware Intelliremote software which claims to work with Creative remote control (Soundblaster Live!, Audigy, Extigy, Audigy ZS and Soundblaster X-Fi.)
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
