Editing Foobar2000:Components
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 192: Line 192:
* [[Foobar2000:Components 0.9/Run Commands (foo_runcmd)|Run Commands (foo_runcmd)]] Search and execute menu commands.
* [[Foobar2000:Components 0.9/Scheduler (foo_scheduler)|Scheduler (foo_scheduler)]] Plugin for scheduling actions like play, stop, system shutdown/wake up and many more.
* [[Foobar2000:Components/Seek (foo_seek)|Seek (foo_seek)]] offers different ways of seeking inside one or more tracks: preview, rewind/fast-forward, loop, and repeat A–B.
* [[Foobar2000:Components/Seekbox (foo_seek_box)|Seekbox (foo_seek_box)]] Main menu item that pops up a box for seeking to a particular hh:mm:ss time in the current track.
* [[Foobar2000:Components 0.9/Send To Device (foo_sendtodevice)|Send To Device (foo_sendtodevice)]] Add "Send to Device" feature.
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
