Editing EAC Drive Options
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 28: Line 28:
: '''Tip #1''': If you're concerned that your drive caches audio data even though EAC is saying otherwise, try ripping a scratched disc (one known to produce errors easily).  Make sure you uncheck the "Drive caches audio data" setting AND uncheck the "Drive is capable of retrieving C2 error information" setting.  Make sure you also set the error recovery quality to "Low" (this setting can be found under the Extraction tab in the [[EAC Options]] dialog). If EAC is capable of displaying a ''read'' error then cache flushing isn't necessary.  Ignore any sync errors that may be displayed; they are irrelevant to this test.
: '''Tip #2''': Tip #1 is all you need to know, but if you're still paranoid that your drive caches audio, feel free to try {{brokenlink|http://www.feurio.com/English/Download/download_install.shtml|Feurio's}} audio caching test (Ctrl+Alt+P\Test device\Cache test) or spath's [https://club.myce.com/t/cache-explorer/167099 cache explorer] (also forked as [https://github.com/xavery/cachex cachex]). Tests should be performed with an audio CD in the drive. If either determine that your drive doesn't cache or caches less than 64 KB of data, then cache flushing isn't necessary (ignore the reported buffer size when using cache explorer).  The reason for the 64 KB barrier is that EAC will never request less than this amount while ripping [http://web.archive.org/web/20140626091839/http://www.digital-inn.de/threads/cache-detection-in-eac.32972 link]).
: '''Tip #2''': Tip #1 is all you need to know, but if you're still paranoid that your drive caches audio, feel free to try {{brokenlink|http://www.feurio.com/English/Download/download_install.shtml|Feurio's}} audio caching test (Ctrl+Alt+P\Test device\Cache test) or spath's [https://club.myce.com/t/cache-explorer/167099 cache explorer] (also forked as [https://github.com/xavery/cachex cachex]). If either determine that your drive doesn't cache or caches less than 64 KB of data, then cache flushing isn't necessary (ignore the reported buffer size when using cache explorer).  The reason for the 64 KB barrier is that EAC will never request less than this amount while ripping [http://web.archive.org/web/20140626091839/http://www.digital-inn.de/threads/cache-detection-in-eac.32972 link]).
: '''Note''': If "Drive has 'Accurate Stream' feature" is deselected, then "Drive caches audio data" is automatically checked, regardless of whether the drive actually caches audio data.
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
Templates used on this page:
