Editing APE Tag Item
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 6: Line 6:
''Note:''
''Note:''
*APE Tags [[APE key|Item Key]] are case sensitive.
*APE Tags Item Key are case sensitive.
*Nevertheless it is forbidden to use APE Tags [[APE key|Item Key]] which only differs in case.
*Nevertheless it is forbidden to use APE Tags Item Key which only differs in case.
*And nevertheless Tag readers are recommended to be case insensitive.
*Every Tag [[APE key|Item Key]] can only occures (at most) once. It is not possible to transmit a Tag Key multiple time to change it contents.
*Every Tag Item Key can only occures (at most) once. It is not possible to transmit a Tag Key multiple time to change it contents.
*Tags can be partially or complete repeated in the streaming format.<br>This is to make it possible to display artist and title if you missed the start of the transmission.<br>It is recommended to transmit very important information like artist / album / title every 2 minutes and additional 5...10 seconds before the end. Be careful and don't transmit these information too often or during passages with high bitrate demand to avoid unnecessary drop-outs.
Line 30: Line 30:
||Item flags
||Item flags
|[[APe key|Item Key]]
||m bytes
||m bytes
||Item key, can contain ASCII characters from 0x20 (Space) up to 0x7E (Tilde)
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
