MediaWiki API result
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format. To see the non-HTML representation of the JSON format, set format=json.
See the complete documentation, or the API help for more information.
{ "parse": { "title": "Hydrogenaudio Knowledgebase:Sandbox", "pageid": 736, "revid": 23269, "text": { "*": "<div class=\"mw-parser-output\"><div style=\"margin: 1em; padding: 1em; border:1px solid #999\">\n<p>Article text<sup class=\"reference plainlinks nourlexpansion\" id=\"ref_reference_name_A\"><a href=\"#endnote_reference_name_A\">a</a></sup> more text<sup class=\"reference plainlinks nourlexpansion\" id=\"ref_reference_name_B\"><a href=\"#endnote_reference_name_B\">b</a></sup> more text <sup class=\"reference plainlinks nourlexpansion\"><a href=\"#endnote_reference_name_C\">c</a></sup>.\n</p>\n<ul><li>Bulleted text<sup class=\"reference plainlinks nourlexpansion\"><a href=\"#endnote_reference_name_B\">b</a></sup></li>\n<li>Bulleted text<sup class=\"reference plainlinks nourlexpansion\" id=\"ref_reference_name_C\"><a href=\"#endnote_reference_name_C\">c</a></sup>.</li>\n<li class=\"mw-empty-elt\"></li>\n<li>intervening text</li>\n<li class=\"mw-empty-elt\"></li>\n<li><span class=\"citation wikicite\" id=\"endnote_reference_name_A\"><b><a href=\"#ref_reference_name_A\">^a</a></b></span> Text for note a.</li>\n<li><span class=\"citation wikicite\" id=\"endnote_reference_name_B\"><b><a href=\"#ref_reference_name_B\">^b</a></b></span> Text for note b.</li>\n<li><span class=\"citation wikicite\" id=\"endnote_reference_name_C\"><b><a href=\"#ref_reference_name_C\">^c</a></b> Text for note c (with extended highlighting).</span></li></ul>\n</div>\n<p>lkhjijhglkjh\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {\\sqrt {12}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <msqrt>\n <mn>12</mn>\n </msqrt>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {\\sqrt {12}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/c878efdf227cf70df28aa7d43cea0069e6f515e9\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.671ex; width:4.261ex; height:3.009ex;\" alt=\"{\\displaystyle {\\sqrt {12}}}\"></span>\n</p><p><br />\n</p>\n<pre>diff = 10 \u00d7 log<sub>10</sub>(P<sub>2</sub> / P<sub>1</sub>)\n\ndiff = 10 \u00d7 log<sub>10</sub>(p<sub>2</sub><sup>2</sup> / p<sub>1</sub><sup>2</sup>)\n\ndiff = 20 \u00d7 log<sub>10</sub>(p<sub>2</sub> / p<sub>1</sub>) because log<sub>10</sub>(a<sup>2</sup>) = 2 \u00d7 log<sub>10</sub>(a)\n</pre>\n<p><br />\n</p>\n<pre> <span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {P_{2}}{P_{1}}}\\right)}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>d</mi>\n <mi>i</mi>\n <mi>f</mi>\n <mi>f</mi>\n </mrow>\n <mo>=</mo>\n <mn>10</mn>\n <mo>⋅<!-- \u22c5 --></mo>\n <mi>l</mi>\n <mi>o</mi>\n <msub>\n <mi>g</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>10</mn>\n </mrow>\n </msub>\n <mrow>\n <mo>(</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <msub>\n <mi>P</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msub>\n <msub>\n <mi>P</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>1</mn>\n </mrow>\n </msub>\n </mfrac>\n </mrow>\n <mo>)</mo>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {P_{2}}{P_{1}}}\\right)}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/9012bc094d3ed004ea4d95de5d48bc1494cd770a\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -2.505ex; width:23.675ex; height:6.176ex;\" alt=\"{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {P_{2}}{P_{1}}}\\right)}\"></span>\n \n <span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {p_{2}^{2}}{p_{1}^{2}}}\\right)}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>d</mi>\n <mi>i</mi>\n <mi>f</mi>\n <mi>f</mi>\n </mrow>\n <mo>=</mo>\n <mn>10</mn>\n <mo>⋅<!-- \u22c5 --></mo>\n <mi>l</mi>\n <mi>o</mi>\n <msub>\n <mi>g</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>10</mn>\n </mrow>\n </msub>\n <mrow>\n <mo>(</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <msubsup>\n <mi>p</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msubsup>\n <msubsup>\n <mi>p</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>1</mn>\n </mrow>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msubsup>\n </mfrac>\n </mrow>\n <mo>)</mo>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {p_{2}^{2}}{p_{1}^{2}}}\\right)}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/ad431f795f30f8b9a8c33955874d6fedb2ef2579\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -3.171ex; width:23.612ex; height:7.509ex;\" alt=\"{\\displaystyle {diff}=10\\cdot log_{10}\\left({\\frac {p_{2}^{2}}{p_{1}^{2}}}\\right)}\"></span>\n \n <span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {diff}=20\\cdot log_{10}\\left({\\frac {p_{2}}{p_{1}}}\\right)}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>d</mi>\n <mi>i</mi>\n <mi>f</mi>\n <mi>f</mi>\n </mrow>\n <mo>=</mo>\n <mn>20</mn>\n <mo>⋅<!-- \u22c5 --></mo>\n <mi>l</mi>\n <mi>o</mi>\n <msub>\n <mi>g</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>10</mn>\n </mrow>\n </msub>\n <mrow>\n <mo>(</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <msub>\n <mi>p</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msub>\n <msub>\n <mi>p</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>1</mn>\n </mrow>\n </msub>\n </mfrac>\n </mrow>\n <mo>)</mo>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {diff}=20\\cdot log_{10}\\left({\\frac {p_{2}}{p_{1}}}\\right)}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/572e95f17c7c1e53b4f788c8d7e02980cf32b433\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -2.505ex; width:23.352ex; height:6.176ex;\" alt=\"{\\displaystyle {diff}=20\\cdot log_{10}\\left({\\frac {p_{2}}{p_{1}}}\\right)}\"></span> because <span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle log_{10}(a^{2})=2\\cdot log_{10}(a)}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mi>l</mi>\n <mi>o</mi>\n <msub>\n <mi>g</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>10</mn>\n </mrow>\n </msub>\n <mo stretchy=\"false\">(</mo>\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msup>\n <mo stretchy=\"false\">)</mo>\n <mo>=</mo>\n <mn>2</mn>\n <mo>⋅<!-- \u22c5 --></mo>\n <mi>l</mi>\n <mi>o</mi>\n <msub>\n <mi>g</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>10</mn>\n </mrow>\n </msub>\n <mo stretchy=\"false\">(</mo>\n <mi>a</mi>\n <mo stretchy=\"false\">)</mo>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle log_{10}(a^{2})=2\\cdot log_{10}(a)}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/eac22f6465a359fefe87f1e58d0e10c0ab9d36a6\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.838ex; width:22.685ex; height:3.176ex;\" alt=\"{\\displaystyle log_{10}(a^{2})=2\\cdot log_{10}(a)}\"></span>\n</pre>\n<p><br />\nsome text that is not formated\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle a^{2}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msup>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle a^{2}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/f564e5dc0b6e68af32ca8614e972f5b36e944a24\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.338ex; width:2.284ex; height:2.676ex;\" alt=\"{\\displaystyle a^{2}}\"></span>\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {\\sqrt {5}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <msqrt>\n <mn>5</mn>\n </msqrt>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {\\sqrt {5}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/2b78ccdb7e18e02d4fc567c66aac99bf524acb5f\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.671ex; width:3.098ex; height:2.843ex;\" alt=\"{\\displaystyle {\\sqrt {5}}}\"></span>\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle \\sum _{n=0}^{\\infty }{\\frac {a^{n}}{n!}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <munderover>\n <mo>∑<!-- \u2211 --></mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>n</mi>\n <mo>=</mo>\n <mn>0</mn>\n </mrow>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi mathvariant=\"normal\">∞<!-- \u221e --></mi>\n </mrow>\n </munderover>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>n</mi>\n </mrow>\n </msup>\n <mrow>\n <mi>n</mi>\n <mo>!</mo>\n </mrow>\n </mfrac>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle \\sum _{n=0}^{\\infty }{\\frac {a^{n}}{n!}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/d9a137cf3055386b232f919ad154afd1579f41ec\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -3.005ex; width:7.026ex; height:6.843ex;\" alt=\"{\\displaystyle \\sum _{n=0}^{\\infty }{\\frac {a^{n}}{n!}}}\"></span>\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle \\lim _{x\\to \\infty }f(x)=0}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <munder>\n <mo movablelimits=\"true\" form=\"prefix\">lim</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>x</mi>\n <mo stretchy=\"false\">→<!-- \u2192 --></mo>\n <mi mathvariant=\"normal\">∞<!-- \u221e --></mi>\n </mrow>\n </munder>\n <mi>f</mi>\n <mo stretchy=\"false\">(</mo>\n <mi>x</mi>\n <mo stretchy=\"false\">)</mo>\n <mo>=</mo>\n <mn>0</mn>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle \\lim _{x\\to \\infty }f(x)=0}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/8ca224044bfa1b0bcdd732c49816668da7fb96db\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -1.838ex; width:13.292ex; height:3.843ex;\" alt=\"{\\displaystyle \\lim _{x\\to \\infty }f(x)=0}\"></span>\n</p><p><br />\n<span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle x=a_{0}+{\\frac {1}{a_{1}+{\\frac {1}{a_{2}+{\\frac {1}{a_{3}+a_{4}}}}}}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mi>x</mi>\n <mo>=</mo>\n <msub>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>0</mn>\n </mrow>\n </msub>\n <mo>+</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <mn>1</mn>\n <mrow>\n <msub>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>1</mn>\n </mrow>\n </msub>\n <mo>+</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <mn>1</mn>\n <mrow>\n <msub>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>2</mn>\n </mrow>\n </msub>\n <mo>+</mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <mn>1</mn>\n <mrow>\n <msub>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>3</mn>\n </mrow>\n </msub>\n <mo>+</mo>\n <msub>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>4</mn>\n </mrow>\n </msub>\n </mrow>\n </mfrac>\n </mrow>\n </mrow>\n </mfrac>\n </mrow>\n </mrow>\n </mfrac>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle x=a_{0}+{\\frac {1}{a_{1}+{\\frac {1}{a_{2}+{\\frac {1}{a_{3}+a_{4}}}}}}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/56ea5502ec025b412f9402c4154571babe7e6cf1\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -5.338ex; width:24.216ex; height:8.676ex;\" alt=\"{\\displaystyle x=a_{0}+{\\frac {1}{a_{1}+{\\frac {1}{a_{2}+{\\frac {1}{a_{3}+a_{4}}}}}}}}\"></span>\n</p><p><br />\nDoes things work after update someone wonders...\nHope the upgrade works!\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle a^{7}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>7</mn>\n </mrow>\n </msup>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle a^{7}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/fba905b10c9ae579baf06be1030590f3a0b81dda\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.338ex; width:2.284ex; height:2.676ex;\" alt=\"{\\displaystyle a^{7}}\"></span>\n<span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle {\\sqrt {7}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <mrow class=\"MJX-TeXAtom-ORD\">\n <msqrt>\n <mn>7</mn>\n </msqrt>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle {\\sqrt {7}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/4ca16e62fc47de4252d87457029895a954d91a42\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.671ex; width:3.098ex; height:3.009ex;\" alt=\"{\\displaystyle {\\sqrt {7}}}\"></span>\ntest\ntesting plugin\n</p>\n<table class=\"wikitable\" style=\"text-align:center\">\n<caption>Multiplication table\n</caption>\n<tbody><tr>\n<th>×</th>\n<th>1</th>\n<th>2</th>\n<th>3\n</th></tr>\n<tr>\n<th>1\n</th>\n<td>1</td>\n<td>2</td>\n<td>3\n</td></tr>\n<tr>\n<th>2\n</th>\n<td>2</td>\n<td>4</td>\n<td>6\n</td></tr>\n<tr>\n<th>3\n</th>\n<td>3</td>\n<td>6</td>\n<td>9\n</td></tr>\n<tr>\n<th>4\n</th>\n<td>4</td>\n<td>8</td>\n<td>12\n</td></tr>\n<tr>\n<th>5\n</th>\n<td>5</td>\n<td>10</td>\n<td>15\n</td></tr></tbody></table>\n<p><br />\n</p>\n<table style=\"width: 256px; float: right; margin-left: 10px; margin-bottom: 10px; border: solid 1px #AAAAAA; background-color: #F9F9F9; font-size: 88%;\">\n<caption style=\"font-size: 130%\"><b>foobar2000</b>\n</caption>\n<tbody><tr>\n<th colspan=\"2\" style=\"text-align:center; font-weight: normal; display:none;\">{{{logo}}}\n</th></tr>\n<tr style=\"text-align: center; font-size: 75%; margin: 0px; padding: 0px;\">\n<td colspan=\"2\"><span typeof=\"mw:File\"><a href=\"/index.php?title=File:Foobar2000v0.9.png\" class=\"mw-file-description\"><img src=\"/images/thumb/5/57/Foobar2000v0.9.png/250px-Foobar2000v0.9.png\" decoding=\"async\" width=\"250\" height=\"174\" class=\"mw-file-element\" srcset=\"/images/thumb/5/57/Foobar2000v0.9.png/375px-Foobar2000v0.9.png 1.5x, /images/thumb/5/57/Foobar2000v0.9.png/500px-Foobar2000v0.9.png 2x\" /></a></span><br />Screenshot of foobar2000 v0.9 using the default user interface\n</td></tr>\n<tr style=\"vertical-align: top;\">\n<td><b>Developer(s)</b>\n</td>\n<td>Peter Pawlowski\n</td></tr>\n<tr>\n<th colspan=\"2\" style=\"background: #DDDDDD;\">Release information\n</th></tr>\n<tr style=\"display: none;\">\n<td><b>Initial release</b>\n</td>\n<td>{{{released}}}\n</td></tr>\n<tr>\n<td><b>Stable release</b>\n</td>\n<td>TBC\n</td></tr>\n<tr style=\"display: none;\">\n<td><b>Preview release</b>\n</td>\n<td>{{{preview_release}}}\n</td></tr>\n<tr>\n<th colspan=\"2\" style=\"background: #DDDDDD;\">Compatibility\n</th></tr>\n<tr style=\"vertical-align: top;\">\n<td style=\"min-width: 90px\"><b>Operating system</b>\n</td>\n<td><a href=\"/index.php?title=Microsoft_Windows&action=edit&redlink=1\" class=\"new\" title=\"Microsoft Windows (page does not exist)\">Windows</a>\n</td></tr>\n<tr>\n<th colspan=\"2\" style=\"background: #DDDDDD;\">Additional information\n</th></tr>\n<tr>\n<td><b>Use</b>\n</td>\n<td><a href=\"/index.php?title=Audio_player_(software)&action=edit&redlink=1\" class=\"new\" title=\"Audio player (software) (page does not exist)\">Audio player</a>\n</td></tr>\n<tr>\n<td><b>License</b>\n</td>\n<td><a href=\"/index.php?title=Proprietary_software&action=edit&redlink=1\" class=\"new\" title=\"Proprietary software (page does not exist)\">Proprietary</a>, <a href=\"/index.php?title=BSD_license&action=edit&redlink=1\" class=\"new\" title=\"BSD license (page does not exist)\">BSD</a>\n</td></tr>\n<tr>\n<td><b>Website</b>\n</td>\n<td><a rel=\"nofollow\" class=\"external text\" href=\"http://www.foobar2000.org/\">www.foobar2000.org</a>\n</td></tr></tbody></table>\n<p><br />\n</p><p>this ist a test\n</p><p><br />\n<span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle a^{6}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mn>6</mn>\n </mrow>\n </msup>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle a^{6}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/e814f0612d12659836368faec51de27af980e239\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -0.338ex; width:2.284ex; height:2.676ex;\" alt=\"{\\displaystyle a^{6}}\"></span>\n</p><p><span class=\"mwe-math-element\"><span class=\"mwe-math-mathml-inline mwe-math-mathml-a11y\" style=\"display: none;\"><math xmlns=\"http://www.w3.org/1998/Math/MathML\" alttext=\"{\\displaystyle \\sum _{n=15}^{\\infty }{\\frac {a^{n}}{n!}}}\">\n <semantics>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mstyle displaystyle=\"true\" scriptlevel=\"0\">\n <munderover>\n <mo>∑<!-- \u2211 --></mo>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>n</mi>\n <mo>=</mo>\n <mn>15</mn>\n </mrow>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi mathvariant=\"normal\">∞<!-- \u221e --></mi>\n </mrow>\n </munderover>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mfrac>\n <msup>\n <mi>a</mi>\n <mrow class=\"MJX-TeXAtom-ORD\">\n <mi>n</mi>\n </mrow>\n </msup>\n <mrow>\n <mi>n</mi>\n <mo>!</mo>\n </mrow>\n </mfrac>\n </mrow>\n </mstyle>\n </mrow>\n <annotation encoding=\"application/x-tex\">{\\displaystyle \\sum _{n=15}^{\\infty }{\\frac {a^{n}}{n!}}}</annotation>\n </semantics>\n</math></span><img src=\"https://wikimedia.org/api/rest_v1/media/math/render/svg/ef2534275485fcea682277470163a8cc49a0440a\" class=\"mwe-math-fallback-image-inline mw-invert\" aria-hidden=\"true\" style=\"vertical-align: -3.005ex; width:7.58ex; height:6.843ex;\" alt=\"{\\displaystyle \\sum _{n=15}^{\\infty }{\\frac {a^{n}}{n!}}}\"></span>\n</p><p><br />\n<a href=\"/index.php?title=Comparison_of_CD_rippers\" title=\"Comparison of CD rippers\">Comparison of CD rippers</a>\n</p><p><br />\n<span class=\"mw-default-size\" typeof=\"mw:Error mw:File\"><a href=\"/index.php?title=Special:Upload&wpDestFile=Example.jpg\" class=\"new\" title=\"File:Example.jpg\"><span class=\"mw-file-element mw-broken-media\">File:Example.jpg</span></a></span>\n</p>\n<!-- \nNewPP limit report\nCached time: 20240615103949\nCache expiry: 86400\nReduced expiry: false\nComplications: []\nCPU time usage: 0.185 seconds\nReal time usage: 0.381 seconds\nPreprocessor visited node count: 212/1000000\nPost\u2010expand include size: 2482/2097152 bytes\nTemplate argument size: 720/2097152 bytes\nHighest expansion depth: 4/100\nExpensive parser function count: 0/100\nUnstrip recursion depth: 0/20\nUnstrip post\u2010expand size: 534/5000000 bytes\n-->\n<!--\nTransclusion expansion time report (%,ms,calls,template)\n100.00% 9.645 1 -total\n 74.54% 7.189 1 Template:Infobox_Software\n 11.83% 1.141 5 Template:Ref\n 6.50% 0.627 3 Template:Note\n-->\n\n<!-- Saved in parser cache with key wiki_2024:pcache:idhash:736-0!dateformat=default and timestamp 20240615103949 and revision id 23269. Rendering was triggered because: api-parse\n -->\n</div>" }, "langlinks": [], "categories": [ { "sortkey": "", "hidden": "", "*": "Pages_with_ignored_display_titles" }, { "sortkey": "", "missing": "", "*": "Pages_with_broken_file_links" } ], "links": [ { "ns": 0, "exists": "", "*": "Comparison of CD rippers" }, { "ns": 0, "*": "Microsoft Windows" }, { "ns": 0, "*": "Audio player (software)" }, { "ns": 0, "*": "Proprietary software" }, { "ns": 0, "*": "BSD license" } ], "templates": [ { "ns": 10, "exists": "", "*": "Template:Ref" }, { "ns": 10, "exists": "", "*": "Template:Note" }, { "ns": 10, "exists": "", "*": "Template:Infobox Software" }, { "ns": 10, "exists": "", "*": "Template:Software Infobox" } ], "images": [ "Foobar2000v0.9.png", "Example.jpg" ], "externallinks": [ "http://www.foobar2000.org/" ], "sections": [], "parsewarnings": [ "<strong>Warning:</strong> Display title \"foobar2000\" was ignored since it is not equivalent to the page's actual title." ], "displaytitle": "<span class=\"mw-page-title-namespace\">Hydrogenaudio Knowledgebase</span><span class=\"mw-page-title-separator\">:</span><span class=\"mw-page-title-main\">Sandbox</span>", "iwlinks": [], "properties": [] } }
