https://wiki.hydrogenaud.io/api.php?action=feedcontributions&user=36.78.23.46&feedformat=atomHydrogenaudio Knowledgebase - User contributions [en]2024-03-29T12:46:55ZUser contributionsMediaWiki 1.22.7https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components_0.9/Peakmeter_Spectrum_(foo_uie_vis_peakmeter_spectrum)Foobar2000:Components 0.9/Peakmeter Spectrum (foo uie vis peakmeter spectrum)2022-05-12T02:43:00Z<p>36.78.23.46: </p>
<hr />
<div>{{fb2k}}<br />
[[Category:Foobar2000 3rd-Party Components|Peakmeter Spectrum]]<br />
[[Category:Foobar2000 visualization components]]<br />
<br />
<br />
==Description==<br />
Foo_uie_peakmeter_spectrum is a foobar2000 plugin that combines a peakmeter with a spectrum analyzer. It requires Columns UI and is the successor of foo_uie_peakmeter. It can be used as a peakmeter and/or a spectrum analyzer.<br />
<br />
<br />
==Requirements==<br />
* [[foobar2000:Components/Columns UI (foo_ui_columns)|Columns UI (foo_ui_columns)]]<br />
<br />
<br />
==Installation==<br />
#Extract the downloaded archive and place foo_uie_vis_peakmeter_spectrum.dll in your foobar2000 "components" folder (normally located at %ProgramFiles%\foobar2000\components\).<br />
#Start foobar2000.<br />
#Open up '''File/Preferences''', navigate to '''Display''' -> '''Columns UI''', and select the '''Layout''' tab.<br />
#Right-click on a splitter and select '''Insert Panel''' -> '''Visualisations''' -> '''Peakmeter Spectrum'''<br />
#Click '''Apply''' to make the panel appear.<br />
<br />
<br />
=Import and export settings=<br />
To open a preset or a settings file please right click on the component and select import. Then you have to select the location of the desired file.<br />
<br />
To save your settings to a file please right click on the component and select export. Then you have to select the location of the desired file.<br />
<br />
=Specification=<br />
[[Image:peakmeter_spectrum_description.jpg|589px]]<br />
==Elements==<br />
<br />
====main bar====<br />
You can customize the settings of the main bar in the goup "Main bar" of the preference dialog. Right click on the component and select "Preferences" to show the dialog. The size can be set individually for the spectrum analyzer and the peakmeter by clicking the button "Options" in the corresponding group.<br />
====additional bar====<br />
The additional bar is only available for the peakmeter. The settings can be customized by clicking the button "Options" in the Peakmeter group.<br />
====bar label====<br />
The bar label can be hidden by deselecting the Show bar label check box in the goup "Main bar". Colors can be configured by clicking the button "Colors" in the group "Global".<br />
====peak indicator====<br />
Peak indicator settings can be customized by clicking the button "Peak indicator" in the group "Main bar".<br />
===Peakmeter===<br />
The peakmeter indicates the instantaneous level of an audio signal. <br />
<br />
The visible channels can be configured by selecting the appropriate item in the peakmeter channel listview and clicking the button "Edit". <br />
<br />
Additional settings can be accessed through the button "Options" in the peakmeter group. In the peakmeter options dialog you can select between peak and [http://en.wikipedia.org/wiki/Root_mean_square rms] display.<br />
<br />
===Spectrum analyzer===<br />
The spectrum analyzer observes the frequency characteristics of the foobar audio output signal in real time. <br />
<br />
You can specify the visible frequency bands by selecting or deselecting them in the spectrum analyzer list view. In addition to this there are three Buttons below the band list view, which can be used to select a part or all bands. Button "A" will select all bands. Button "2" will select every second band. Button "4" will select every forth band.<br />
<br />
By pressing the Button “Options” in the spectrum analyzer group you can customize the accuracy and select or deselect the audio channels. [http://en.wikipedia.org/wiki/Fast_Fourier_transform FFT size] and the [http://en.wikipedia.org/wiki/Window_function window function] have a great influence on the quality of result.<br />
<br />
==Link==<br />
* [http://www.hydrogenaudio.org/forums/index.php?showtopic=61149 Discussion thread]<br />
* [http://www.hydrogenaudio.org/forums/index.php?showtopic=61145 Download thread]</div>36.78.23.46https://wiki.hydrogenaud.io/index.php?title=SpectrogramSpectrogram2022-05-10T04:07:11Z<p>36.78.23.46: </p>
<hr />
<div>{{Stub}}<br />
A spectrogram is a graph showing the distribution of energy between frequency bands over time.<br />
<br />
The data that is necessary to create such a graph is gathered by transforming [[time domain]] ([[PCM]]) data to [[frequency domain]], e.g. using [[FFT]].<br />
[[Category:Signal Processing]]<br />
[[Category:Technical]]</div>36.78.23.46
