Editing Monkey's Audio
Jump to: navigation, search
Warning: You are not logged in.
Your IP address will be recorded in this page's edit history.
The edit can be undone. Please check the comparison below to verify that this is what you want to do, and then save the changes below to finish undoing the edit.
Latest revision Your text
Line 6: Line 6:
| maintainer = Matt Ashland
| released = {{start date and age|2000}}
| recommended_encoder = 5.38 (April 26, 2020)
| recommended_encoder = 4.77 (10 June 2019)
| website = [https://www.monkeysaudio.com monkeysaudio.com]
| website = [http://www.monkeysaudio.com monkeysaudio.com]
'''Monkey's Audio''' (APE) is a freeware [[lossless]] audio compression format with a highly competitive compression algorithm, and is used primarily by Windows users. Although software is available for Linux, Monkey's Audio is not as popular among this operating system's users. Monkey's Audio suffers from slow decompression speeds as compared to other lossless audio codecs.
Line 18: Line 18:
==See also==
==See also==
* [[Lossless comparison|Lossless Codec Comparison]]
* [[Lossless comparison|Lossless Codec Comparison]] by Rjamorim
* [[EAC and Monkey's Audio|Configuring EAC and Monkey's Audio]]
==External decoding==
* [https://www.foobar2000.org/components/view/foo_input_monkey Monkey's Audio Decoder for foobar2000] Provides decoding support for (.APE) Monkey's Audio files.
==Installing==
* [https://www.foobar2000.org/components/view/foo_input_ffmpeg FFmpeg Decoder Wrapper for foobar2000]
Go to Monkey's audio download page and download the latest installer for your system, double click the installer and run.
*find a suitable audio recording (.WAV), or record an audio session using [[Audacity]] and save to PCM (.WAV) , now proceed and run Monkey's Audio, select your (.WAV) audio file and compress, you now have an audio file compressed in (.APE).
==Decoding==
Recommend decoding with foobar2000.
*foobar2000 - [https://www.foobar2000.org/components/view/foo_input_monkey foo_input_monkey] component provides decoding support for monkey's audio files (.APE).
Alternative decoding with foobar2000 and FFmpeg.
*foobar2000 - [https://www.foobar2000.org/components/view/foo_input_ffmpeg foo_input_ffmpeg] component provides FFmpeg support with '''FFmpeg Decoder Wrapper'''.
*FFmpeg Decoder Wrapper
*Zeranoe FFmpeg Builds http://ffmpeg.zeranoe.com/builds/
Setting up FFmpeg Decoder Wrapper in foobar2000.
*Download the '''[https://www.foobar2000.org/components/view/foo_input_ffmpeg  foo_input_ffmpeg]''' plugin (Double click on the plugin to Install), Next from foobar2000 '''Menu''' select Option >> Configure >> Playback >> Decoding >> FFmpeg Decoder Wrapper > select 'Monkey's Audio' tick box, also within '''FFmpeg Decoder Wrapper''' option screen, you can browse location for FFmpeg.
foobar2000 Menu select Configure > playback > decoding > FFmpeg Decoder Wrapper ( Monkey's Audio )
*FFmpeg Decoder Wrapper requires ffmpeg
*Assign Path for FFmpeg in Windows 10
Windows 10 - Assign path for ffmpeg in the Enviroment Variables
Windows 10 users you can also '''Assign''' a '''Path''' for '''FFmpeg''' from the ''''System Properties''' >> '''Enviroment Variables''' ( Use Windows 10 Search, to find '''Enviroment Variables''' )
select system variables Path > edit > new > C:\ffmpeg\Bin assuming you have ffmpeg extracted at this location.
Select '''Path''' from '''system variables''' >> '''Edit'''' >>'''New''' >> '''Add''' >> '''C:\ffmpeg\Bin''' , assuming you have '''FFmpeg''' extracted at this location.
==Players==
Additional Supported software for playing (.APE) audio files.
*[[foobar2000]] + Plugin ( Windows )
* [https://www.un4seen.com/ Bass audio library] supported players using Bass_ape.dll for decoding.  [[MusicBee]], AIMP, Tag scanner ( Windows )
* [https://getwacup.com/ WACUP] (WinAmp Community Update Project)
*Winamp + Monkey's audio installer ( Windows )
*[[VLC]] plays (.APE) YES, seek bar is unresponsive when playing. ( Windows / Linux ? )
== Encoding Monkey's Audio with foobar2000 ==
In this guide we are going to show you how to access foobar2000 "Quick Convert" and create a new custom preset,
the new preset will allow you to encode (.WAV) audio files to Monkey's Audio (.APE).
Quick Convert:
To gain access to Quick Convert you need to Right Click a selected (.wav) audio file, this action will open the context menu
from the context menu select "Convert > Quick Convert", This action will open Quick Convert > Now click the "Add New" button,
this will open the "Commandline Encoder Settings" > Now click on the encoder menu and select custom.
You are now ready to edit your preset.
Parameters Modes:
      fast        -c1000
      normal      -c2000
      high        -c3000
      extra high  -c4000
      insane      -c5000
Example custom preset using normal.
      Encoder file: C:\Program Files\Monkey's Audio x64\MAC.exe
      Extension: ape
      Parameters: %s %d -c2000
      Format is: lossless (or hybrid)
      Highest BPS mode supported: 24
      Encoder name: APE (Monkey's Audio)
      Settings: normal
Now to save your preset click OK. You are now ready to convert any audio file with (.wav) extenstion to (.ape)
this setup was tested using "sherpya" ffmpeg x86_64 build.
==External links==
==External links==
* [https://www.monkeysaudio.com Monkey's Audio] - Official website
* [http://www.monkeysaudio.com/ Monkey's Audio] - Official website
* {{wikipedia|Monkey's Audio}}
[[Category:Lossless]]
Please note that all contributions to Hydrogenaudio Knowledgebase are considered to be released under the GNU Free Documentation License 1.2 (see Hydrogenaudio Knowledgebase:Copyrights for details). If you do not want your writing to be edited mercilessly and redistributed at will, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource. Do not submit copyrighted work without permission!
Cancel | Editing help (opens in new window)
