Editing Foobar2000:Components/Quicksearch UI Element (foo quicksearch)
Revision as of 12:40, 10 April 2010 by NEMO7538 (talk | contribs) (New page: thumb|right|405px|Quick Search '''Page under construction''' =Description= Derived from ''foo_uie_quicksearch'' and ported to foobar2000 V1.0.x, available as ...)
(diff) ← Older revision | Latest revision (diff) | Newer revision β†’ (diff)
Warning: You are editing an out-of-date revision of this page. If you publish it, any changes made since this revision will be lost.
Warning: You are not logged in. Your IP address will be publicly visible if you make any edits. If you log in or create an account, your edits will be attributed to your username, along with other benefits.
Please note that all contributions to Hydrogenaudio Knowledgebase may be edited, altered, or removed by other contributors. If you do not want your writing to be edited mercilessly, then do not submit it here.
You are also promising us that you wrote this yourself, or copied it from a public domain or similar free resource (see Hydrogenaudio Knowledgebase:Copyrights for details). Do not submit copyrighted work without permission!
Cancel Editing help (opens in new window)
