https://wiki.hydrogenaud.io/api.php?action=feedcontributions&user=188.30.40.2&feedformat=atomHydrogenaudio Knowledgebase - User contributions [en]2024-03-28T08:46:18ZUser contributionsMediaWiki 1.22.7https://wiki.hydrogenaud.io/index.php?title=Monkey%27s_AudioMonkey's Audio2019-05-19T21:57:48Z<p>188.30.40.2: Version update</p>
<hr />
<div>{{Codec Infobox<br />
| name = Monkey's Audio <br />
| logo = <br />
| type = lossless<br />
| purpose = A fast and powerful lossless audio compressor<br />
| maintainer = Matt Ashland<br />
| released = {{start date and age|2000}}<br />
| recommended_encoder = 4.73 (15 May 2019) <br />
| website = [http://www.monkeysaudio.com monkeysaudio.com]<br />
}}<br />
'''Monkey's Audio''' (APE) is a freeware [[lossless]] audio compression format with a highly competitive compression algorithm, and is used primarily by Windows users. Although software is available for Linux, Monkey's Audio is not as popular among this operating system's users. Monkey's Audio suffers from slow decompression speeds as compared to other lossless audio codecs.<br />
<br />
Monkey's Audio uses a combination of traditional lossless compression tactics ([[linear prediction]] and [[channel coupling]]) and a simple [[neural network]]. To store the output values of its prediction step it uses [[range coding]], modified to work well with more or less continuous values.<br />
<br />
Its main competitor is [[FLAC]], which has more features than Monkey's Audio (streaming support, for example) and hardware support to its advantage, though its efficiency in compression is not as great.<br />
<br />
Monkey's Audio is released under a "custom" license that allows you to do pretty much anything with the source code, on the provision that you ask the author for permission.<br />
<br />
==See also==<br />
* [[Lossless comparison|Lossless Codec Comparison]] by Rjamorim<br />
* [[EAC and Monkey's Audio|Configuring EAC and Monkey's Audio]]<br />
<br />
==External decoding==<br />
* [https://www.foobar2000.org/components/view/foo_input_monkey Monkey's Audio Decoder for foobar2000] Provides decoding support for (.APE) Monkey's Audio files.<br />
<br />
==External links==<br />
* [http://www.monkeysaudio.com/ Monkey's Audio] - Official website<br />
* {{wikipedia|Monkey's Audio}}<br />
<br />
[[Category:Lossless]]</div>188.30.40.2
